lectric80
3/4 ton status
I have never seen any concrete numbers, and in fact the only experience I have is just using what is already there. I plan to replace the condensor in my Blazer when I get through the rebuilding, and of course will be using a parralel flow type unit, but that is only because those who do refrigerant have recommended it.Sure, the added efficiency comes from the extra surface area - more gas is touching metal at all times - and parallel paths (hotter gas is spread out over more area), but it's not proportionately that much more area directly exposed to the air flow. I've never found any real numbers except the 30% efficiency figure. None of those statements said anything about saving space or making the unit smaller. AC Delco talks about saving weight with their "replacement" unit, but never mention improving performance. What is the definition of condenser efficiency, if it's not amount of heat removed at a certain refrigerant and air flow?
It only makes sense that the replacement units would be parallel flow, as that's what the factories will be set up for. They save on extra tooling and save on material.
I do know that even with a slightly smaller unit, there is still a lot more surface area in the piping to help remove the heat. But, I don't know how much more efficient that makes the unit versus using a slightly larger tube and fin condensor. Even the AC Delco unit doesn't seem to make much sense because there really isn't that much weight in a condensor.
