Wiper Motor Wiring 1974
Chief Brody
"Amity Island Welcomes You"
Alabama
Can anyone verify that I have the wiring on right?
Colors on mine are different, but I believe so. Dead give away will be to try it. Worst case, the low and high speeds might be swapped if the bottom (three wire) plug is reversed, or the squirter might not work or might pop a fuse if the top (two wire) plug is wrong.
-- A
I flipped the connector over...still not working...
The wiper motor grounds out at the switch. If the switch don't have a good ground, the wiper won't work.
If I had to guess, I say the yellow with the black tracer wire is 12+. Check to see if you have power up to there.
