wiper questions
sweetk30
Back to play nice .
in the back of your brain
if you have a basic off/low/high and swap to a switch with delay is there a problem ? and not using the delay box .
also is there a specific part # to wiper motors for delay or non delay ?
this is all on a 87c-k body truck. was factory non tilt wheel and non delay. swaped in delay/tilt wheel setup.
simptoms are works kind of. wipers start then stop 1/2 way up. linkage is all free and lubed like its riding on hot butter. :D
truck sat for 6-7 years with no use prior to fixing up and driving.
i think the wiper motor is d.o.a on this thing my self.
Brett, I had that same symptom on the Maiden, it was the switch...although mine is dash mounted. seems the sitting for many years without use caused some corrosion in the switch and would work in the low position intermittently, rapidly cycling the switch back and forth clears it up for the most part.
I threw up a thread about intermittent stuff, check it out for more clarity onthe subject:
http://coloradok5.com/forums/showthread.php?t=290173&highlight=76zimmer
