Wipers work well, except when you put them in high they stop working. Would this lend towards the module under the column? I feel like this has happened before and that is what my problem was....
Yes i would do the stalk first then its the motor itself
Did you check to make sure that the motor has a good ground, it has its own ground strap
Is there a way to test if it is the stalk wire for high speed or if it is the wiper switch wire for high speed. The stalk is not that bad of a job, but that dam wiper switch is a pain in the ass
