Wire Label Maker
pomai
Oahu, Hawaii
Any suggestions on wire label makers?
something to use in cab, engine compartment and easy to use?
Thank you,
Ed
Thank you,
Ed
i run some pretty dainty sticker stuff thru a cheap brother p-touch for tagging stuff, etc...
I use a handheld from walmart. i think its a brother also. Works fine but you want to get plastic tape not the paper tape. The labels are a bit heat sensitive. Most of them are a thermal printing tech so they can discolor in high heat areas.
