Wiring 240v 50 amp plug to my compressor
Shawn
Nuckin Futz!
Author
5280'
I had a 240v 50 amp circuit installed in my new home's garage. I did this to power my 240v welder and 240v compressor. Now I need to figure out how to somehow wire this. I won't be using both at the same time. The compressor only needs 15 amps so it only needs a 20 amp fuse/breaker. The current plug is a 4 wire, and both welder and compressor only use 3 wire. Should I install some type of sub-panel with a 20 amp breaker or fuse? How would you wire this?
I'd just change the current 4 wire receptacle out with a 3 wire one that matches your plugs. That receptacle has a neutral in the center flat blade used only in dryers and stoves usually.
It can be disconnected, scotchlocked off, and pushed to the back off the box.
Not that model but the correct similar one lol
Thanks! I was thinking of one of those adapters or just switching the plug out. If I switch out the receptical to a 3 wire I wonder if I should add a ground strap? I'd also like to add some protection to the compressor. Was also thinking adding breaker(s) in a small box just for the compressor since there is no off/on switch.
I'd put an on off switch on the compressor myself. But adding a sub panel is an option yeah.
You wouldn't have to add a ground strap either. Your 4 wire already has a dedicated ground. You would just put the 3 wire receptacle in place of the 4wire one, and not use the white wire... No strap needed
Took you advice and bought a 4 wire to 3 wire adapter. Then modified compressor plug so it matches my welder.
