Wiring diagram
True.... 1987 GMC Jimmy full size 5.7
It's in the link provided, I just checked. '88 and '89 would be pretty similar, but as long as the download works for the '87, use the correct year. You'll often find one or two changes, which can be frustrating if it's a circuit you are dealing with.
All the connectors save VERY few are labeled (with a letter or number) for each cavity, don't go by wire color. it might work, but people make that mistake all the time. Go by the terminal position in the connector, and the wiring diagram should specify which cavity is which circuit, by letter or number on the connector.
