wiring gauges... C60 style tach w integrated fuel
RootBreaker
3/4 ton status
Williamstown, NJ USA
yes it is me again... havent touched the truck for a long time..
im going to attempt to wire the gauges...
sooooo i have the old harness....
trying to decide what wires are the grounds...
so anyone have the pinouts for a 78 chevy?1 through 18?
i do see
4, 6, 16 - pink w/black stripe all tie together
7,18 - pink tied together
3, 8, 10 - black - gonna assume ground?
1 lt green - H Beam indicator - ok so connects to where???
2 grey -
5 lt brown -
9 dk green - temp
11 lt blue - oil sender
12 blue - rt turn
13 yellow
14 yellow
15 dk blue - l turn
17 lt brown w/white stripe
gonna try and wire some of this up tongight...
now im wondering if black is ground
and the pink w/black stripe goes to light switch for lights????
thought this would be a good place to archive a good doc i found.. shows many years and what pin on the connector and where it goes...
The two pink wires are for the fuel gauge. Pnk/bck strip are ign. hots. black is ground. Oil gauge should be a tan wire. Grey is the inst. cluster lights. And I cant remember the rest.
i do see
2 grey -
5 lt brown -
9 dk green - temp
12 blue - rt turn
13 yellow
14 yellow
15 dk blue - l turn
rgr
i do see
1 lt green - Hi beam indicator
2 grey - inst. cluster lights
5 lt brown - oil gauge
9 dk green -temp. gauge
11 lt blue - l.h indicator
12 blue -
13 yellow
14 yellow
15 dk blue - R.h indicator
17 lt brown w/white stripe- brake warning light
The yellow wires should be for the seat belt warning light.
well i get to throw all that out the window....
i hooked up a mess of it... yeah turn signals worked... power, gnd, oil...
but i just remembered im putting in a different gauge cluster...
totally different pinout...
GRRRRRRRRRRRRRRR from a 1960ish or 70ish C60..
the one with the gas gauge on the tach...
anyone happen to have wired one? i know some guys here did.. so ill have to search and ask.... got to take kid to soccer first though...
so brb...
while back i bought the old style dump truck or c60 series chevy gauge cluster....
it has volt, oil (mechanical), temp, vacuum gauge in the small locations...
has large speedo and large tach (to 5k) with integrated fuel gauge....
well now i looked at the wires and thought maybe only a few will be different.... well no electric oil so there goes one wire.... fuel gauge is moved.. so what i have to figure out... and ill get it...
but if anyone did one of these conversions... did you write down what was what? yes im gonna use the search feature... but im at soccer practice for my kid... so thought id post first...
my pins are as follows..... and what i think i figured them out to be
1. green - high beams
2. grey - headlight switch controlls dimming
3. black w/white stripe - volt meter +
4. black - ground for volt meter
5. / 12. Red - Power
6. No connect
7. / 18. Tan - gas gauge
8. green - temp sender
9. black - 2 wires - ground
10. grey - left turn
11. blue - right turn
13. - bulb in w. speedo (plastic missing so not sure if it is break light)
14 - 17 - no connect
so that is it... seems like everything is covered too... so going to try and wire a few tonight....
