Wiring Harness for K5 72 Blazer
You get what you pay for. The only thing I would suggest on Painless is to solder instead of crimping. Crimping will be fine for a year or two but after the wires start to corrode you will not make good contact, then you will have bigger problems. I used M&H Engineering for my wiring. They make OEM harnesses. I had like $600 for a total rewire. I bought it thru Tuckers. Tuckers sells it cheaper than thru M&H.
http://www.wiringharness.com/
Usually the cheaper the harness,the MORE complicated and involved it will be to install.
I used M+H stock replacement harness and it was a simple plug-n-play deal.
http://wiringharness.com/
The painless harnesses have to be "adapted" to OUR year trucks.
It also depends on your skill level and how comfortable you are with automotive wiring.If you compitant with wiring, go with the cheaper harness/wiring system.
Finances are also something to consider.
Personnaly I wouldn't skimp on your vehicles wiring.The more expensive harneses use quality wire,are properly wrapped,have the mounting clips wrapped into the harnesses and line up to all the factory mounting holes.
They also have the proper terminal ends already crimped and soldered on.
Just something to consider.
are you guys using any grease for the connections between the fusebox and the front firewall wireharness. I've seen some harnesses corrode in that area.
ARQ.
I use dielectric grease on all the electrical connections I mess with. It gives a better electrical connection and prevents corrosion. Cheap insurance.
I don't know what kind of dielectric grease the factory uses but that black/brown stuff gets over everything.
I used a quality marine dielectric grease.
