454Sub
5/8 ton status
Originally my truck was a 90 1/2 ton 2wd with a 350/700 combo. It now runs a 454/400/doubler, hacked into the original harness. I have access to a 4wd 91 4l80e, with the entire donor truck harness and adapter. I would love OD. So my question is, can the factory 1/2 ton 90 harness be separated at the fusebox, and instead be partially wired with the donor trucks harness to tranny, and obviously replace with the donor truck ecm, and fusebox as well for the tranny fuse, or will entire harness have to be swapped?. Can anyone possibly give both pinouts an eyeball and see if this is possible. Thanks.
