wiring problem please help
k51977blazer
Cocoa Florida
I have a 1977 blazer with 350 4x4 ok well first my headlights work highbeams work turn signals work,its inside is what is baffling when i turn on my turn signal to the right it barley blinks and my needles on my guage start to move when i turn it to the left the right side blinks like it should and the needles move real fast any ideas on this.
Start by looking at the grounds very important then go get a new flasher real cheep so you know its good.
I had kinda the same thing except no issues with the gauges,turned out the flasher was jacked.One side flashed good the other did not.
Mike
question
Mike
yeah but but the left side doesnt flash at all when i turn it to the left the right side flashes.everything is fine outs ide of my blazer everything works.It just inside when i turn on the turn signals.
Just to clarify:crazy: you are telling us that the right and left flashers work out side just fine and the right indicator on the inside works but the left don't or both don't work on the inside???
Does the emergency flashers work inside???
wiring problem
Does the emergency flashers work inside???[/quote
Everything works on the outside but its just on the inside when i turn my left turn signal on it sorta blinks on the right side nothing on the left when i turn my right one on it blinks normal and the guages move.The hazards are the same way just the right one blinks and the guages move but whats got me baffled is everything on the outside works i turn my flasher on everything works right turn signal left turn signal headlight highbeams everything work on the out side it just something to do with the turn signals.I didnt think it would be my flasher cause i hear it.Its a crazy problem i might be able to take a video and send it to your email
that would work,Ill try and help u out!! [email protected]
Mike
