buffblazer
i went and put aftermarket gauges in. just those cheepo 3 pack, oil,water,and amp gauges from napa. i wired them up and im kinda questioning i did it right, i ran the wires for the lights all together and hooked them into the power wire that runs my kc light switch, which then runs thru a relay and a fuse, then to the battery. any possibility that the 3 inst bulbs in the gauges could cause the fuse to blow or cause the wires to over heat? and then when running my amp wires down to the starter i was wondering what size fuse should i put on it? i was just gonna put a in-line fuse and it comes with a 25 amp fuse already in it, and should i put a fuse on both sides? one going to the starter and one leaving the starter? sorry so long but any help would be great.
i think i screwed up
