I’m trying to replace a male terminal in the junction block that plugs in to the fuse panel but I don’t think I have the correct terminal.
I have what is supposed to be a packard type 56 terminal but it’s not fitting the slot. I expected it to push in and somewhat snap / lock in place but it does not. No matter what I try it only goes in so far and stops, at this point it’s only exposed half as much as other existing terminals. When I tried to force it the terminal begins to deform.
Am I using the wrong part? Special secret handshake required?
The blade is the correct width (.250) but the existing terminals don’t appear to be split like the new one (see circle). I’m trying to insert it into the headlight power slot at the bottom (see arrow).
