wiring / wiper questions
jekquistk5
Weld nekid
Pinckney, MI
I need some help with wiring my wipers. I had wipers non delay style with the switch(hi/lo/off) on the dash by the headlight switch, before I swapped the TBI harness and motor in. The column is a tbi style, and it has a non delay switch. The truck I pulled the harness from had delay style wipers. Anyone know what wires do what for delay etc. I want to just put a traditional rocker switch hi lo and off. Help please I can not find my wiring diagrams.
hmmm
my 85 is non delay
solid black from dash is power
white is ground
redish is for squirters
and the others just tie into each other from the switch
that's how mine is, hopefully it's right, only wired it a couple days ago but tested it and passed:whistle:
Jess would an 85 wiring diagram help you? I have a service manual I can make some copies of for ya.
i miss my hi lo and off switch Jess. i HATE everything being run through some kinda main source . the Volve i have been driving at work has major problems. the guages are fuked.electronic BS. only the air and fuel work.i'm slowly getting JR new guages to replace the cluster.:D
