Soooo, I put a cluster in my k5 today, didn't have one when I got it. Everything hooked up, speedo doesnt work, I can make it work by turning the cable though. Next, when I turn on the blinkers, the amp gauge dips with the signal, the indicators on the dash go back and forth. For instance, lever down for left, left flashes, then right, the left and vice versa with the lever up.....
Im "thinking" ground issue? The right indicator is on full time, all bulbs are new and function..
The cluster I have is from a late 80s, has a light blue plug coming out next to the speedo cable that I have no idea the purpose of. My tub and main wiring harness is from a 79, could this be an issue?
