Wobble
bigblue82
Registered Member
sc
I just replaced the tired 350 with a newer one at the same time i dropped the tranny thinking i was gonna change it out.I eventually put the same th350 trans back in.Now i have a bad wobble and a slight knock just sitting in park.While im driving there seems to be less of a wobble on deceleration.Can anyone help out?
You might not have your transmission tourqe converter in all the way. It may have slipped out a notch when it was removed. Check to make sure the flex-plate bolts are all in and tight.
