Hey guys,
I searched for the death wobble, and didn't quite find the same symptoms I'm having, so here they are...
I installed a 3/4 ton front 10b axle in my truck, after running a 14b with no problems for a while. However, sometimes when I hit a dip or a bump on the street, I get a massive wobble in the front end until I manage to stop. It doesn't happen any other time.
Anyone know what might cause this? My knuckles have new ball joints, but the steering components to not. I reused my old stabilizer which worked fine before the swap. I'm also running without a sway bar, but I was without it before the swap as well.
Thanks,
Adam
Thanks,
Adam
Correct, I ran just a rear 14b around town until I got another front 10b with 8 lugs and the right gear ratio. All was fine before I installed the new 10b.
