It may not be quite that lean at idle, it is pretty unhappy and it may be miss-firing a bit causing error. I had it set in the 15s before and did a quick reset after changing the power valve and ifr wire and haven't had a chance to fix it. The Tcc problem is kind of a bitch. The problem is it is a single point switch. So below the set point it unlocks but of course as soon as you decrease the load the vacuum rises above the set point. I have 2 factory vacuum delays but they really only slow it about 1-2 seconds. It really needs a switch with a high and a low so you can set a low point to unlock and it won't relock till you get to a high point. I had my EE buddies help me design a "latch" circuit with a second switch and relay but I haven't ordered another switch yet. We did talk about building a micro controller with an Arduino and a map sensor but, ya seems like a $1000 saddle for a $10 horse. Right now it will drop down below my 6.5inhg set point on some fairly mild hills that it wasn't before. I figured out that I made a pretty big jump going to the .012 wire (about 85%) of what it was before I am thinking of just going back to 80%. The rpms are a tad higher than 1500, at 1904 rpm for 65 mph and 2050 rpm for 70 mph. Either way I am mostly just playing and can go back.. I also bought air cleaner, 2 hoses and the round hose connectors that hold the hoses to the rad support yesterday. Hoping to build a dual snorkel air cleaner this weekend.
