No way any Canadian truck kept points or carb's longer than US trucks. All of our emissions crap as well as safety crap is adopted cart blanche. By '75 everything was electronic ignition...
Thats what I always thought too--the trucks I saw pulled into the parts store I worked at,the owner requested plugs,points,and condensor--he got pissed and said "My truck HAS points"..
I told him GM stopped using them after 1974,and he said "come see for yourself"...
He opened the hood,sure enough,it had a points distributor,no EGR,and only a PVC valve..(It may have been a one ton truck too,I cant recall)..
He insisted he owned the truck from day one,and had this argument every time he went to buy parts for it..
I said it was probably not original,someone either swapped an older engine in it,or put the points distributor in it and "deleted" any other emission equipment,but he was adamant he was right...
My boss said do not argue with him--SELL him what he wants!..
I wrote that truck off as a fluke..
A few months later another canadian built truck came in,that had the same setup on its 350...not saying your wrong,just telling you what I ran into...maybe they were some high GVW emission exempt trucks?..
Another weird GM I saw at a gas station was a 1976 Monte Carlo they were fixing..the mechanic said "hey Bob,your a GM man--come check this engine out--ever see this before ?."..
I peek under the hood,and saw a 305 or 350,with a strange dual 2 barrel intake,two Rochester 2GC carbs mounted diagonally across from each other,with dual factory air cleaners !...looked completely factory,the intake and engine were the same color,intake was cast iron too,not aluminum...had a factory looking progressive linkage on the carbs..
Mechanic said he'd never seen anything like it either--and the owner of the car insisted GM tried buying the car back from him,told him he HAD too,and they would give him anything of equal value as a replacement..
They said it was some "experimental" design ,that was not supposed to be released to the public...supposedly when he refused,GM threatened to take him to court ....don't know how that ever turned out!..he also claimed the car got over 20 mpg often,but would "boot and scoot" when you floored it..evidently GM was not impressed with the setup,as it never went into production..
