That will work !!Am considering drilling the heads and safety wire
I am not sure if I understood your comment correctly but these mounts have sleeves and you torque down the bolts and they shouldn't loosen up.Nords can’t hurt in this application but since the mounts give under torque the washers will be asked to hold while the bolts simply can not maintain compression and that’s no fault of the retaining method chosen.
I’d use good ole thread locker and verify nothing is loose as regular maintenance.
