would these be good cheap stainless brake lines?
I can't make out the ends very well but it looks like they have all ready screwed the ends into the line. Even if they are the wrong lines I THINK you should be able to go to a brake parts place (or order online) and get the ones you need. The round end would proly work fine but I can't see the other very well. Can you contact him and ask for a better pic of just the ends?
These would be for a metric truck. The end the banjo goes in would prolly work all right but I dunno about the other.
I think when it comes to brakes, I dont want the word CHEAP associated with them. lol Just order a good set from either ORD ( I think they carry some) or Summit. I got mine from summit and have been happy with them. they are an inch or two longer.
thats true, i havent skimped on my truck yet and i dont want to start. good point.
on the other hand, i dont think ive got the metric stuff being an 85. and the bolt with the hole in it that goes into the caliper is an 11mm head on the new trucks. not sure on thread pattern or diameter. its probably more headache than its worth.
X2.
Calipers when from standard to metric banjo bolts in '78 or '79 IIRC. Also, check these guys out. I just ordered a couple lines for my 14BFF discs. They should be here tomorrow. :pimp:
