MattK
Factory pump (fresh reman), Rock Logic 1.5x8 ram. No cooler or extended neck on pump.
My power steering fluid has been milky ever since I got my K5 back on the road. I have always had crappy steering to no steering at idle.
Milky fluid could at least be part of the problem right? So I'm thinking I can run the return line coming from the box into a waste bucket, and then the return line into the pump into a bucket with fresh fluid.
Would cycling the steering with this setup flush my system?
