AussieK5
Ditto...the difference in weight between various valve stems (rubber vs steel vs long neck stems) at the outer portion of the rim will have far more effect than a few grams +/- at the centre. I'd mark out a centered circle and die grind to it.
For that matter is there weight added/subtracted at the opposite edge on the rim to compensate for the valve orifice and fitting when its cast or rolled. Not that I've ever seen.
