chevy wrangler
now im just confused???? can i run a zero rate on the front??
yes. they are only $34 right now so if you want them then i would jump on it. you have to make sure you have at least an extra inch of thread left on your u-bolts... on the rear you should be fine. on the front you might have a problem. just order some new ones. im suppose to get mine this tuesday so ill post pics up if you want to know what it would all look like. you would have to lengthen the driveshafts which im getting a guy to do next sat. and should be done by monday... im so excited! i finally get to run my big b!+@%!chevy wrangler said:now im just confused???? can i run a zero rate on the front??
are they belted bajas??? because their has been some bad things said about those. also your xterrains are probably more expensive than those anyways right?chevy wrangler said:i wanna look up her skirt thats why i wanna full 10" !!LOL
okay so the tires are they good or no??
my procoms came out to $1350 with 15/10 procomp steel wheels, mounted and ballanced and free valve stems and lug nutsx2. keep the xterrains for awhile. there are better deals on here if you want bigger tires. also ntwonline.com usually has deals on tires for real cheap... and they aren't crappy tires. stick with your game plan... unlike me.yellowK20 said:Yeah that deal is way in the other guys favor keep what ya got plus your kinda pushing it on the limits of halfton axles
you will be alot happier.SUPERSUB87 said:$1350? where did you get those from?
x2... i was suprised with what my 33's can do. only got stuck once with some super cheap wal-mart terrains.yellowK20 said:master them 35" first you'll be surprised how much you can do with them
Plus if you wanna bog 38" throw you up with the big boys
i've been hitting the dunes down here, its kool we got wased out water bakns full of rocks and thats why my u-joint decided it had enough
but its all goodyellowK20 said:master them 35" first you'll be surprised how much you can do with them
