I also lifted the engine enough to clear the mounts, unbolted the mounts, and cut the crossmember in front of the engine to pull straight out.That was a manual, but yes I don't like pulling the tc on the flex plate. The possibility to damage tc or pump, not mention making everything longer, is to high
Moisture doesn't only come down.If it sat outside for a long time the hood was still on the K5. I wonder how then the engine could have been so water logged and the internals rusted. Maybe it was in a flood.
