WTB: 10B/44 Front in IN or KY area
bigjimmy82
1-Ton Status
New Albany, IN
I am looking for a ready to run or at least someting out of a driver...
44 or 10 Bolt Front Only
3.73 Gears
8-Lug
open
Complete lockout to lockout preferred but not a must.
Closer to 47130 ZIP(Southern IN/Louisville Area) the better, hopefully no more then 200 Miles
Tim
I have exactly what you're asking for above.
10 bolt with 3.73's and Spicer lockouts with open dif.
Upgrade to a D60 front with 3.73's, open and brand spanking new bearing hubs/rotors instead. I have this also.
I have one too, it's an 8-lug 10B w/ 3.73 gears, open diff, from a '79 3/4T 'Burb, complete with Warn Premium lockouts. It is located in Bowling Green, KY. You'll just have to be patient if you want mine. It's still under the front of my project truck. I have a D60 to swap in its place, but I need to rebuild it first. I Probly won't have it ready for a couple months.
ive got 10 bolt with 3.73 gears thats under a burban but i could have it out this weekend. im located in ashland, ky and ill take $150 for it
I could bring you a 6 lug 10 bolt of you want something to hold it off the ground?
Duntz, want is the condition of the axle?
I'll just throw out what I have, even though it's not exactly what you're looking for...
I have a front (and rear) 10b from an 86 K5. I was going to use these under my Mazda in the future, but they're just taking up space. It's currently a 6-lug setup, but I have all the parts to convert it over to 8-lug. The hub, lugs and calipers are original; rotors, pads, bearings and seals are all brand new. The only bad things are that the axle hasn't been "used" in about a year and I'm pretty sure it has 3.08 gears. I'd take $250 for everthing (mostly the cost of the 8-lug setup) and I could bring it to you or meet up in New Albany (where I work).
Thanks, but I need to drive it between now and the D60 swap, and I only have 8 lug wheels. I'll let you know when I have it out (if you haven't picked up another one in the meantime).
14b is going in and I am still in need of a 3.73 10-Bolt, 6-lug would even work and I can convert it, just not looking to tear into regearing another axle.
Still in need, would consider a 10 bolt, 44, or 60, if it is within a reasonable distance.
