Texis
Still needing (2) 1310 front K5-K10 drive shafts for a cj project. A couple of you guys responded (thanks)....waiting on pics & answers to Qs...still need these!
I should be able to get you the pics today, you still didn't tell me if you want flange or yoke style CV so I will take pics of both, I have a few of each.Still needing (2) 1310 front K5-K10 drive shafts for a cj project. A couple of you guys responded (thanks)....waiting on pics & answers to Qs...still need these!
Nice.
I need the CV end to terminate with a 1310 joint (not a flange)....to mate to the jeeps D18 case. So I believe the official term is "double cardan" joint.
But>>> isn't the flange held on with a 1310 joint? SO> I believe I could simply remove the flange side of the u-joint?...is that correct?
well I have the one I showed you, and I did find another, but it's not as big a tube as the other one, but if you are going to retube them, then this will work, it's from a Jeep wagoneer has a smaller diameter tube to clear the engine.Still needing a couple of the non-flanged 1310 front drive shafts.
I have 2 shafts like you're requesting. Let me get pics later after work today.Still needing a couple of the non-flanged 1310 front drive shafts.
So you think it's that easy huh?
