WTB: 1350 Driveshaft
longbedder
3/4 ton status
Staff member
Moderator
Ridgecrest, CA
The junkyards here have really gone downhill in the last few years...not sure what the issue is, but whatever...
I'm looking for a driveshaft, specs as follows:
One piece shaft with t-case slipyoke
Slipyoke for 241/208 tranfer case
1350 U-Joint compatibility
Minimum length 43" ujoint-center-to-ujoint-center
Lemme know whatcha got...I'm in Ridgecrest, CA.
I have one near Seattle if your friend is heading this way. Out of a 1 ton longbed with NP208/14FF. ~59" Ujoint to Ujoint with the slip yoke and ujoints. $25
Thanks Kenny...I'll get in touch with him and see. I doubt he'll be anywhere near Seattle but it's worth checking.
Weld-to-weld on my current one is 36-3/4" but it's a Saginaw 44 shaft, and it's not quite long enough now (I moved my axle back a bit). So I would need minimum 38-1/4" weld-to-weld. I can get it shortened if necessary.
I have a bunch, I will measure them.
Do you come up this way at all?
I wouldn't want to ship this thing.
I do go down that way occasionnaly but you'd have to be available on short notice to meet with me.
