WTB: 14 bff srw hubs
SgtHighway
Buffalo, NY
Contact with pictures if you have a pair and are willing to part with them for 50 bucks or around there. If you want more, message me anyway and if they're in good enough shape I might be interested. In Hamburg NY but will pay for shipping. Thanks guys!
EDIT: will also trade for my DRW D70HD hubs
I got a whole parts axle 14ff srw hub setup .
got it in a package deal and it had junk gears so I got it for parts only .
I am down the road a bit 14845 zip horseheads ny if you wana come get it and make a deal .
haven't torn in to it yet other than poped cover to find junk gears.
Tempting but a bit out of my way, at that point I'd just go get gouged on a junkyard set. Thanks though man!
if I get time anytime soon and you still need I let ya know if I strip it .
and fyi shipping not cheep these days . priced a set of drw hubs for a guy and was close to 65-70 bucks .
so maybe local pick-n-pull is best.
just make sure there NOT from newer pop off drum style . you need the pressed on with stud style.
all depends on a few things . seen them overlap a lot .
just got to look to be sure .
if drum in front of hub = pop off style
if drum behind hub = press on
and fyi shipping not cheep these days . priced a set of drw hubs for a guy and was close to 65-70 bucks.
But that was going to the far side of the country too. Going across the state should be more reasonable since it is in the same shipping zone. May be a little more than the cost of gas to go pick them up, but probably worth it if your time is important to you.
