WTB: 32 spline input 205
Bogger Man
White Pine Co. Nevada
Looking for a 32 spline input 205 to go behind a th400, preferably fixed yoke rear/flanged front, thanks.
**edit**
I have decided to do a doubler after all so, I am looking for a short 32 spline figure 8 pattern 205. Thanks again.
I don't have one but more info will be needed...
Do you need the 205 to fit a round or figure 8 pattern adapter?
I don't have the tranny or the adapters yet. I do have access to a th400/203 and a th400/208, so more than likely it would need to be the round pattern for a bolt on application to replace the 208, right? I don't really know, I'm still kinda new to the automatic scene. Pretty sure the one with the 203 will require the most work tho!
well if you ever plan on doing a doubler kit then get the 400/203 . then ditch the back half of the 203 tcase. save the range box front half.
then get a short input 32 spline or ford 31 spline.
then get doubler kit and bolt it all up.
Thanks sweetk30 I was just going to do a th400/205 set up, but now you have twisted my arm into going with the doubler set up:wink1:. Peer pressure is a b*tch sometimes.:D So now we all know what I am looking for, thanks!
