WTB 6.2L Diesel - SoCal
Jambi
Temecula, Ca
I need a motor with out main-web cracks. Located in SoCal but willing to drive for a good motor.
preferably a running motor (I'm probably dreaming), but I may end up rebuilding one.
Cost is always a factor and it eventually it becomes a better option to just do a re-power with a cummins or something.
A rebuild is always an option, what do you have? :xmas:
Well I have a long block that was supposed to be a runner, I will need to check compression before I say anything, and I have a couple of rebuildable engines as well as a clean 599 block from a Hummer, I have rebuilt IP and some used ones, I have J code intakes as well as C code, I have some heads, and a Banks turbo with all the parts.
If you want to do some work I could cut you a deal on a bunch of parts, I have no more time to do what I want, and plenty of projects that will never see light, so might as well give them a chance.
