WTB Beauty ring and cap
Code3K5
Registered Member
Torrance, Ca
I need a beauty ring and cap for my spare tire. I recently moved my spare tire to the rear bumper and it needs a ring and cap just to look good :waytogo:
Prefer local seller, have cash:popcorn:
Not local, but I have extra beauty rings and caps here. OEM caps, not that plastic crap LMC sells. I can snap a few pics if you want...there are a couple of different versions of beauty rings, and I have a small assortment.
Rene
First style I have, this is the thinner ring
This is another "thin" one, doesn't appear to be factory.
This is the wider factory ring.
Center caps I have. All approx the same condition which I'd put at fair to good. There is a little pitting, but they should clean up OK. Not sure if you want a front cap or a rear. A front would work in either location should you have a flat, a rear is only going to work on the rear. Not a big deal as they're easy enough to remove...
Close up of the pitting, that is pretty typical and all of them. They are pretty dirty too. The set on my truck right now were similar but did clean up pretty good.
Also, the beauty rings all have a little overspray on them. If you want a ring and a cap i'll see if it cleans up or not. If not I'll throw the ring with overspray on my truck and send one of the clean ones to you off my truck.
Rene
