Like the title says, want to buy a passenger drop dana 60. Im in Arizona but Im willing to drive pretty far to pick it up. Complete is preferred but show me what you got.
That first one looks like a 44 they are trying to pass off as a 60. The second one looks legit though, thanks.
It sure doesThat first one looks like a 44 they are trying to pass off as a 60. The second one looks legit though, thanks.
That’s a 60. One ubolt and studs. Plus flat kingpin plate on bottoms of knucklesThat first one looks like a 44 they are trying to pass off as a 60. The second one looks legit though, thanks.
Upon closer inspection they actually have pictures of two different axles in the post. One clearly shows the single ubolt and studs like you mentioned. Another pic, the one showing the whole axle, definitely shows a 44.That’s a 60. One ubolt and studs. Plus flat kingpin plate on bottoms of knuckles
2 different axles in the same ad pics .That first one looks like a 44 they are trying to pass off as a 60. The second one looks legit though, thanks
That pair is actually a pretty good deal at $4500 considering they have a ton of work done already.www.facebook.com
www.facebook.com
and if you decide to go to the 05+ super duty Dana 60 axle: https://hogbackfab.com/products/73-87-gm-super-duty-d60-frame-side-radius-arm-brackets
Thanks but Delaware is a little too far from Arizona haha.I have a D60 drw and rear D70 in DE if you feel like coming up, 1800 for the pair.
I definitely will not be using a Ford 60 which is why I specified a passenger drop in the title.Having messed with superduty stuff, I would advise spending the money on a GM D60 and bolt it in. T-case swap can be a pain and exhaust is likely a real problem unless stock manifolds are your jam since headers are basically impossible. Plus bolt pattern f$*&ery in the wheel and tire game along with terrible ground clearance at the frame and axle.
Cummins swap tow rig? Definitely on the list to consider. Hardcore rock rig, probably the right thing. Anything else, probably not a good idea.
I have a complete d60 4.56 gears.Like the title says, want to buy a passenger drop dana 60. Im in Arizona but Im willing to drive pretty far to pick it up. Complete is preferred but show me what you got.
