WTB: Driver's side Power Window Harness for K5
DK5
The city that rhymes with fun, Saskatchewan
I need the power window harness including the switch as far as you can get (to the plug at the other end would be nice, or I can solder it in to mine).
Its for a '90 K5, the old switch is done and the wires are hacked where they come in the door.
Thanks
I can sell you a complete harness all the way to the connectors inside the drivers kick panel w/ switches for $75 shipped.
thanks Kenny, I'm interest. I also found someone that has one locally (maybe) so I will let you know by this weekend hopefully whether I will go for yours or not.
Are the switches in good shape?
The switches worked, but all stock switches seem to be part of the slow window problem eventually. The only good way to eliminate that is a set of relays wired correctly.
did you do relays in your truck? Its a no-brainer IMO, I might as well do it now while its all apart. Found this thread, is there a better one somewhere else?
http://coloradok5.com/forums/showthread.php?t=206618&highlight=power+window
I will probably get your harness but I'll see if I can get ahold of the local guy first, just because it would be faster if he has it- then I could just throw it in this weekend.
Well, local guy didn't have one, but I'm rethinking the whole idea now...
My window doesn't roll all they way down for some reason and its painfully slow. So, I'm thinking new motors, wires, switches, weatherstripping, glass (full of scratches) and relays like you did. More research is needed though, I might start a new thread.
Found this universal harness at LMC:
http://www.lmctruck.com/icatalog/bzc/full.aspx?Page=100
