Do you need to put hubcaps on them? If not, just painting the stock ralley wheels black (or white) is a good temp solution. If you want to run hubcaps the M1009 CUCV is the best bet. However, don't forget that Toyota & Isuzu also used the same 6 on 5.5" pattern. Good luck- I'm still looking for a set as well.
