WTB: GM dana 60 SRW hubs.
muddysub
1 ton status
Staff member
Moderator
North Branch MN
i need a pair of hubs, with or without rotors and studs. i machined the DRW hubs on my 60 down and they're not quite right. i'd rather just grab a set of SRW hubs if anyone has some for sale, that'd be awesome, otherwise i'll buy some from ORD.
I have a set that is kinda rough. one hub took a hit that bent the end a little bit where the hub lock ring goes, and the other was machined kinda off center so the metal is thicker on one side than the other. I was just keeping them for spares, but I didn't want to use them for a build, so I doubt you'd want to. pics if you wish.
on another front, brand new GM hubs/rotors are available from http://www.gmpartsdirect.com/ for ~$193 each with rotors. part number: 15635530
Well I think I'll pass on your hubs but thank for the link! I think I'll go that route.
I bought a set from them. they are as pictured, with wheel studs and all. no bearing races though, IIRC.
