WTB- heat only setup (planning to delete A/C) to fit an 85
blowedupmotor87
Charlotte, NC
Looking to buy the heat only setup (box, squirrelfan, heater core, and dash controls, the complete setup) to be able to delete A/C. Thanks!
I have one I just pulled from an 86 to install a vintage air set up. I was thinking $100 plus the ride for everything.
Everything worked just fine. Thats everything I pulled out minus the little push on nuts that hold the cables to the hinge rods and the misc nuts and screws. You should have plenty when you pull your set up though. The only thing not pictured that I will include is the wiring harness from the switch to the resistor. THe guy that bought the Blazer just wanted A/C, so I installed a Vintage Air kit for him. Ill get a shipping quote in the morning.
