WTB K30 hangers and shock mounts
USSkoval
Thornbirds look cool... Yeah, I said it
Fayette County, Ohio
I'm looking for a set or rear spring hangers for a K30, and also the upper shock mounts that attach to the frame. I need to get this project done and these are the last pieces to the puzzle. Thanks.
just an idea, you could get the diy4x shock inboard kit, but then ud have to move the shock mounts that are on the axle.
i actually might still have the shock mounts on my k30, i inboarded the shocks. ill check and see if ive still got them on my frame, if so ill grind the rivets off and let you know
I was under the impression that the inboard kit would not work on a burban (which is what I have).
Anyway, I figured I could make the 1ton stuff work so a 1ton 14ff will bolt in. I may have found a set of brackets, but I'll let you know if I end up needing the shock brackets.
I have these parts here,
I have a M1008 on site I'm about to part make an offer If its worth my time I'm go take them off and ship out to you.
You will likely have to modify the shock mounting brackets off of the 1 ton frame to fit in a Suburban frame as a minimum. The 1 ton's have a deeper frame rail than the Suburban.
