wtb - L-brackets / k5 emblems
drew4x4
clarksville, tn
i need a set of the L-brackets to mount the second t-case cross member...
and i also need a set of k5 emblems, preferably nos, or at least in good condition for an 80 k5.
lemme know what you got!
thanks yall
drew
2 " L " brackets with 2 bolt holes on each edge . 1 each side of frame and down around to bolt the extra crossmember in place.
1 extra crossmember from same style you have IE: 1/2-3/4 ton or 1ton frame .
then the skid plate is bolted to them .
I have some and can check my stash and get back to you .
sweet man, let me know.
based on the picture... if its the same size cross member... it should bolt straight to the frame? no L-shaped brackets required? unless it replaces the 1" spacers my front cross member has?
thanks for the link! anybody got one layin around?
i already went and checked our local junkyard. they don't have any 4x4 square bodies.
I don't have the right crossmember but I do have bunch of the skidplates like you need for this setup. I don't have the L-brackets though.
does anybody have the extra transfer case cross member and skid plate for a 80's k5?
is it identical to the first cross member?
(if so i still need the skid plate)
thanks
drew
I have a few of these cross members.
give me a zip so we figure the shipping then we will see if we can make a deal.
I have a torque mount-sandblasted and painted with new poly bushings.
Will ship to you for $50, will get pics this weekend.
