WTB----- NP208c 27 spline, pass drop (th350c)
Kaiser85
Tyler, Texas
Title says it all. Im lookig for a GOOD np208 that doesnt leak, to replace the one in my 81 k5. Id LIKE to have an np205, but unless it comes with all the stuff to make it bolt up directly, ill stick with the 208. This thing wont see too much off roading.
Yeah if you have the th350C, the only tcase that will bolt up with no hard work, is a 208 or 241 27 spline.
I think I just let my last 27 spline 208 go, but I will double check to see if I have any left.
You didn't say where you are, this thing is not cheap to ship so better find one local.
It's also worth mentioning that 208s that came behind 700r4s are 27 spline as well, which should be easy to find.
Thanks xeno. Im new at all this, but no stranger to it all. I was wondering if the 208s that were behing the 700r4 bolted up. I guess the coupling is different, but id use the one i already have, correct??
I think they might be the same, just a different adapter. Someone else will probably chime in though with a definitive answer.
A 208 and a 241 are the same
I have 2 208's here that both were behind 700R4's, both seem to be good, but I haven't been into either. I have been getting $150 for them.
Ive got a good 208 in my garage. Not sure of your location... it doesnt show from tapatalk on the phone.
If you are close to socal you can have it for $80
