WTB prop/combo valve for 80's K5
tRustyK5
Elbows up!
Author
In my garage
I'm replacing all my brake and fuel lines on my '90 and getting rid of the non functioning ABS stuff. The lines I have are for non abs and the first run goes from the master to the front cross member where the prop/combo valve lives. On the rear ABS rigs the prop/combo is at the master and doesn't appear to be easily relocated and made to work.
If anyone is parting a K5 and the prop/combo doesn't look too crusty that'd be great.
Also, if anyone has the front SS braided extended brake lines for a 10 bolt that'd be cool too. I have the rear one already.
I may have a PV Rene,I'll have to dig around in my shed..
I know I have one off a first gen truck,but I'm not sure how good it is,or if they are the same-looks the same to me,its just mounted near the master cyl,not on the frame member...
I know most GM full sized cars in the late 60's and 70's ,maybe even later,used the same PV as the 1/2 and 3/4 ton trucks did,so if you go looking locally for one,there is another source you might want to check out...
I remember using one off a '72 Impala on one of my trucks,and another from a 70's Caddy Coupe DeVille...
I'll look around and let you know if I find one..
I might be over thinking this then...if one from a pick-up would work I can probably score one off Dean. I was thinking the front/rear brake bias was different for each PV on each type of vehicle.
I got one...along with those inner fenders for you!
But I still think the inners are a bit to rusty?
