WTB: speedometer T adapter 4 bolt for manual trans
RootBreaker
3/4 ton status
Williamstown, NJ USA
Since i have a manual trans... i have a T adapter that connects to my xfer case.... see link below that says if you have the 4 bolt style you can get parts for it.. i need to do this to fix my speedometer to be correct. I have the 3 bolt style now.. and told cant get parts for it..
do you have one extra?
do you have any info on the 4 part ones and where to get parts?
appreciate it all...
http://coloradok5.com/forums/showthread.php?p=2929463
ok... ill have to get the unit i have now set back up and in... got a new cable to pickup tomorrow.... then can see how far off it is...
Don't hook the 3 bolt ratio adapter back in, screw your speedo cable directly onto the t-case driven gear and then check to see how far off it is and in which direction THEN you can buy the correct ratio adapter.
ahhh like duhhhhhh that makes sense.. :haha:
well my xfer case has a male end.... and so does the cable.. I did notice that it seems the xfer case spot has a HUGE bolt around the threadded part.. am i supposed to unscrew that... and remove the male portion (sounds sick...)....
