WTB: Stock Rear Driveshaft - 208/12bolt
Vee
Lancaster, CA
I'm looking for a stock rear driveshaft that goes between an NP208 and 12 bolt axle under a blazer
Yes a 12b is 1350 where a 10b is 1310. You can always get a conversion joint though.
Actually a 10 bolt has a 1330 and the 12 bolt has 1310 but yeah they are different.
1330 is same size cap but longer cross than a 1310, the 1350 is bigger caps.
I might have the DS you need but I will have to look when I come back home on Sunday.
81/82 were the only actual factory years for a 12 bolt behind a np208 , by 83 it was only 10 bolt rear in K5's .
Otherwise grab whatever 80's np208 shaft and run a conversion joint like the rest of us :D
I thought GM phased out the 12 bolt in 1979. :dunno:
I know that my 80 has a 12b(for now), and I have seen one 81 with a 12b as well.
But unless you know it was original (RPO code) many people have swapped parts in these rigs. :deal:
How many blazers are out there with a 14ff?
I have a 14 bolt FF, I'm just looking for a spare DS..... I used a combo u-joint and kept my original 12 bolt/208 DS, so I just want to find another one. 10 bolts use smaller u-joints, so I'd rather find a 12 bolt since I have a spare combo u-joint already
