WTB support rod brackets for 6.2
brett37
san diego
Looking for the two brackets that attach to the block sandwiched between motor mount and block. The 6.2 brackets are different from the gas motors any help would be appreciated.
You need the rods that bolt to the flywheel cover to the motor mounts?...if so i can check tomorrow i think i may have a set
Brackets
Thanks for inquiring the part I need is the bracket the rod bolts to on the motor end. Hope the pictures explain.
Brett
