what happened to your crank? The lock cylinder in mine wont lock for some reason. The crank itself is easy to remove. Just remove the access panel, remove the 4 bolts holding the window to the regulator, remove the 4 bolts holding the regulator to the gate, remove regulator from the gate, remove 2 nuts holding crank to gate, and crank is now free to pull out of gate.
