It should not be called Murphy's law... They should change it to McGuire's Law.
The cap style rocker fits right over the new full rocker. Since both doors have the same problem it has to be the part. However, we measured the old bottoms vs. the new bottoms and they are the same.
Also, I measured across the cab from the center of both door strikers and the pillar distance is very close to the spec's that I have.
Given that the driver door striker area on the driver side pillar had to be replaced as the old was cracked, and that the driver door does latch onto the new striker.
Will look into "fitting" that cap rocker on. However, if I do that the door molding will be really messed up. I guess since I have the old molding I can put the new where it belongs and the old on the "cap style rocker" but that will look like crap.
2 hours later... read a lot of posts on other threads... I think I have to relook at the basics.
1. I am working in my driveway and it is old and rutted. I think that I have to take almost everything back off and raise the truck until the frame is level. There is a spot between the cab body mounts that appears to be flat and level so I will use that point to work on. My thinking is that there may be "torsinal" (is that a word ) stress's that are being caused by the truck not being exactly level.
Update: The passenger rear and driver front had to be raised... now frame is level. Raised each about 2 inchs.
2. Next I have to get the pillars at the right height. I do not have the cab floor support brackets welded in. In previous posts I comment how far away the outside ends of the rear floor supports are from the rocker panels, the front supports are very close. There is something really wrong there I am sure. I am going to move the doors strikers so that they are exactly this same distance from the pillars, using the passenger striker as my guide since that has never been moved, and then re-measure the distance between them. Per the spec's they should be 1858 cm apart. If they are within 1 to 2 CM of that I will accept that.
Update: Raised the cab until the rockers were level from front to back. HOPE THIS IS CORRECT !!. Put a angle thingie.. lol It shows that the angle of each rocker panel is about 8 degrees from level. Higher on the cab side lower on the door side.
I also discovered that after losening the body mounts the rear cab supports can move at least an inch closer to the pillar.
Should the rocker panel be level from inside to outside?
The cab weatherstripping bead is tilted in towards the cab so I know I can hammer that towards the door to get it closer to the door.
The weatherstripping on the windshield pillar comes down strait until it hits the rocker panel then is curves inward toward the cab. Reverse happens at the stricker side.
Also the weatherstripping is flush with the door until it hits the rocker panel. (Again pics coming after recharge of camera battery)
3. Then I will put the doors back on and see if they have come closer to the rockers. I believe that this is so important so that the door bottoms are up against the rubber door gaskets so wind, and dust dont get in. (Since I am moving to Vegas I dont want sand getting in...)
Sound like a plan ?
So would you agree with the following:
1. The new rocker panel should be around the pillers rather than inside the pillers ?
2. The angle of the rocker panel should be level both front to back and left to right ?
Please advise
