With the key on I have no power, but when I turn to start I have power. This is a problem b/c as everyone knows, it won't stay running...
Alittle background, I swapped the truck over to TPI using a street and performance wiring harness and the corvette ECM (can't remember the number off the top of my head). The motor was running fine , I just swapped in a Dana 60 front and on my test drive I shorted out the battery and burned up a fusible link. I replaced the fusible link today and now I have no power with the key in the run position. I checked every other fuse that I can find and they are all good.
