stallion85
I would be kind of scared to look in them
stallion85 said:I would be kind of scared to look in them![]()
MTBLAZER89 said:I really don't see how flat towing it could do anything to either axle. Everything was spinning free whether the hubs were in or not should also not matter. Sounds to me like something was wrong already, and the hi speed just finished it off.
Not sure yet. I looked at the rear axel and the gear oil was shooting out the top breather hose. I need to make sure thats what happened up front also. I noticed the front breather hose aims toward the
M-1028 said:If your transmission or T case have alot of drag on them, such as them being damaged or possibly running them low on fluid that drag is going directly through the driveline to the pinion in the axles. When you pulled it 65 you basically turned the pinion into a contantly holding break and generated tons of heat, I am pretty sure thats was your problem as for the front being engaged sounds like the hubs
ryoken said:any update? pics?
. It was not a 4X4
