thebird00 said:
gmc4cw, how did you figure out where to put the tabs for mounting the ram? I've heard that you can use the stock stabilizer bracket but I'll probably cut that off and use the thicker tabs.
Any tricks to getting the measurements right?
I cut the stabilizer bracket off. it didn't work for my ram. I tacked the tabs to the axle tube as close as I could to diff the center section. I bolted the ram in loosely. Then I turned the wheels all the way left and with the ram fully extended marked on the tie-rod with chalk. turned the wheel all the way to the right, compressed the ram and rechecked the mounting point on the tie-rod.
once you know its right, burn everything in tight.
I did not tap the stock end cap, I bought a JKWoffroad cap. as for the stock top cap, theres plenty of thickness there, and there is pretty much only one spot to tap it. I
personally think that the fittings are more protected then a box that has the fittings on the side of the box.
If you can remove the steering pump from the engine bay then you can modify it yourself. I didn't unbolt the pump, just removed the fitting from the back. When I drilled it out I got one perfectly curled sliver of steel. I made sure to use a brand new drill bit.
I am not in any way bashing WTO. I remember finding out about them and thinking the price was great and that I was going to order one. Then after some further searching I discovered I could save
HUNDREDS of dollars. You still have to install everything yourself, so paying hundreds more to have everything come in the same box is not that big of an advantage to me.
