VA WTS 1990 K5 Blazer
Galvinator77
Newbie
Stafford, VA
Too many projects so I need to let something go. For sale my 1990 K5 Chevrolet Blazer 4x4 Silverado, loaded with all power options. Odometer reading is 316,879. Interior is clean, no rips or tears in upholstery, (dash cover and carpet behind rear seat show their age). Good tires with factory rally wheels and center hubs installed. Believe the spare tire is the original Uniroyal tire on a rally wheel. Truck has running 350 cu in (5.7L) TBI Fuel Injected engine, 4 wheel drive works great. Axles have been rebuilt (3.43) gears w/ a limited slip rear differential. Radiator has been replaced with a new all metal one (no plastic tanks). Cruise control works. Factory tow package. Warn manual locking hubs installed. Battery converted to top post with Solargizer quick disconnect brass terminal lugs. NOW for the bad stuff, the 700R4 tranny has a blown forward gear cluster (my failure to require OEM parts in a tranny overhaul), it has working reverse gear so can be moved around, but no forward gears. The heater core leaks and A/C does not work. Some rust inside the tail gate frame area and rocker panels but solid everywhere else (I’m the second owner and the truck sat outside in TN for several years before I got it). Price includes a new OEM unpadded dash cover, new heater core, headlight upgrade kit w/ new headlights and wiring harness, original set of 4 premium aluminum wheels. Also included are two front fenders, a bumper with brush guard (needs work), and extra door hinges off a M1009. Twenty five year age means no emissions required. Eligible for historic tags which means no inspection required. Located in Northern VA. Asking $2000, (price reduction) email (Galvinator77 at gmail) or text me at (Seven zero three) 477-5871 for more info and additional pictures.
